These must be the nuttiest crash bars ever. Simply TOO low.
I appreciate that they are intended to protect our $1600-a-piece fishtails, but when (not if) you touch them down in a corner, you will have every chance to lose traction at the back, potentially resulting in a spectacular Crash Bar Test.
I suggest these instead.
All fun aside you are completely correct. The danger of these bars is real and a result of no oversight.
The moment these touch down the rear wheel will lift, lose contact with the ground and create an irreversible situation.
As you suggest, scratched pipes will be the least of your worries.
Installed the Freedom pipes today. MUCH better sound than the stock mufflers, and sounds like a proper 1800cc should imho.
Couple notes on the install:
- As others have said, no instructions with the kit. But there is a set of instructions someone else posted online (I am including them here). Freedom's website seems to be a bit wonky lately and I could not find this or an updated version on their website.
- The instructions I have suggest the pipes come with rubber hose connectors to join the mufflers to the header pipes. Mine came with metal pipes with a chrome finish (which doesn't really show anyway because the heat shield still covers it). Seems like Freedom switched to a chrome pipe for this part.
- It was a pain in the ass to get the mufflers to seat fully on the header pipes. Whether this was because of the new metal connector pipes or not I do not know. A rubber mallet was absolutely necessary to get it to fit right.
- Fit and finish are good. No complaints about the looks at all.
- The instructions are not clear how the heat shield for the connector pipes are to interface with the heat shield that covers the cat. It looks like the cat heat shield is supposed to go over the connector pipe heat shield. But on the left pipe for me it didn't fit quite well enough. This could be due to the alignment of the system but I did my best to get it to seat fully and still no luck.
Will post pictures once I have time and energy.
The latest … black rear rack, black Indian tracker handlebars, R18B front fender, Rizoma bar ends, and a bit of white pinstriping.
Wow. Very nice striping. I pondered a bit about adding them to the side, but couldn't decide on what angle. Parallel to the ground; you nailed it. And love the fender.
Nice touch with the loom at the bar. Well done all around!!!
Im digging the yellow light bezels and the wind deflectors. Which seat is that?
Thanks. The yellow is a clear vinyl overlay for lights. They are cut from a sheet sourced from Amazon that has served me well. The seat is a de-labeled Mustang Day Rider.
Thank you. There is not a lot of real estate to work with on the side panels! A case of simpler is better was in order, I think. The horizontal ties the fender and the tank together and seems to reinforce the bike's low stance.
The loom was pretty straightforward. Though the bars were pre-milled for pass through wiring, the exits were under the clamps! Rather than mill another hole that risked weakening the bars, I decided to wrap everything to include the hydraulics. If I can find another similar bar that is not pre-milled, I might reconsider.
A2D2DBC3-88B9-410F-BB8F-75993EAF6C90.webp8A53F5AE-C8A9-46B6-B7D6-0A884BAE8CD6.webp6C0AE62C-9D58-4A0B-A868-47C08F38E7E7.webpInstalled wunderlich black engine bar, wunderlich knee pads on the fuel tank. Deleted the US red reflectors on the saddlebags and installed RSD exhaust tips on factory classic exhaust. Time to put some more miles on it now that the weather has finally melted the snow here in Michigan!
