Star-Lord
Yeah..?? New brake pedal changed my life... Or at the very least my braking habits..Interesting that the larger pedal came standard on my Pure 2021 FE Deluxe model and not standard on the B.
Yes of course. One should not be using the front brake while turning. Isn’t this basic 101 of how to ride a motorcycle?I've been riding linked braked bikes for at least a decade, but I still manually use the combination of levers 70/30 in normal braking and rear only for slow manoeuvres. I have raised the height of the standard foot lever, which I found very useful.
There is a lot more info online and worthy of research. Spending a day on the track is enlightening.Really... I always go to the front brake (feather it) when going into a sharp turn, I find it compresses the front shocks, which for me (mentally at least) puts more grip on the front tire and slightly changes the geometry of the bike.
I feel as though I'm dipping into the turn with more confidence, and I think slightly faster than my riding buddies...
Thoughts...
If you are good enough to trail brake properly and to feather the front brake so as to slowly load the front tire, go for it. Risky business for most. Especially off the track where dirt, sand, and other traction devouring detritus is common.
For 95% of us we should be getting all our braking done while the bike is in a straight line. It is just physics. The front tire has a limited amount of grip. If you use some of the friction for braking you lose that for cornering grip.
The brief moment the front tire loses corning traction on a highway there is no recovery.
For 95% of riding outside of a parking lot, the front linked brakes on a bmw provide the natural, and some would argue best, street distribution of 70/30. For parking lot maneuvers the rear is your only friend.I'm probably thinking too much into it... a lot of my riding is poor muscle memory at this point, I'm probably braking while the bike is straight and inline with the rear wheel, just prior to execution of dipping into a sharp turn..
Anyway.. since adding the larger foot pedal, I do see an increase in my rear brake usage..
I agree 100% in making a U-Turn in a tight stretch of roadway; the rear brake and clutch is my friend...For 95% of riding outside of a parking lot, the front linked brakes on a bmw provide the natural, and some would argue best, street distribution of 70/30. For parking lot maneuvers the rear is your only friend.
Regardless of the idea of it being beneficial or not, I am not following how a larger brake pedal would increase the use of the brake.
Can you set your front turn signals to always on the they will still blink if you activate the blinker. In short, set them as “DRL”I used GS-911 to switch off the top case brake light which was throwing an error code on my TC that I have turned into a bagger. It's in - coding - braking - additional brake light - uncheck the checked box, that's it job done.
I also noticed that under additional brake light, that the check box option for - act as running light was NOT checked. I never checked my top case to verify that it did operate as a running like but it seems unlikely it was, so if you have access to a GS-911 you can now do this too.
I didn't check. I'll have a look in a day or two, but the abilities of the options are shown here: https://www.hexgs911.com/function-chart/#K001_K35_R18TCan you set your front turn signals to always on the they will still blink if you activate the blinker. In short, set them as “DRL”
There is a aux or driving light option on there that will turn on and keep the center lights of your head light on anytime the switch is on as a DRLCan you set your front turn signals to always on the they will still blink if you activate the blinker. In short, set them as “DRL”
What Mirrors are those? They look good, and I like the blind spot mirror!Installed my Heli Bars... what a great difference!View attachment 10687
Yes you can. They are on a reduced percentage of brightness and blink at 100% brightness when activated.Can you set your front turn signals to always on the they will still blink if you activate the blinker. In short, set them as “DRL”
It's an option shown on my TC.Above pertains to 2022 fe
