Transcontinental wind deflectors on Bagger
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Frank Bullitt
Are the part numbers provided in the pic everything I need?
Do I need any mounting hardware? If so could you quantify how many lets say, Isa screws or mounting clips, etc. I would need?
Thanks again for all your help.
I just saw an early post where I called out the required hardware and quantities:
I picked up my winglets today and the 4 longer screws and the 4 spacer buffers. Looks easy enough to install but not sure where the spacer buffers go. Help please.
That video should help, let us know if you need anymore help 👍🏽
I added "Memphis Shades" lower wind deflectors to my R18B. I had to modify the brackets to fit my bike as they dont make them for the R18 yet. They took care of about 85% of that lower wind buffeting.
Good morning Aztec78,
Do you have the exact part number or model of the Memphis Shades lower wind deflectors you purchased?
Thank you in advance,
