Petrus
- Joined
- Jul 18, 2025
- Messages
- 1,409
- Location
- Vva. del Rosario - Málaga - España
- Bike
- R18 sidecar, Nimbus Type C sidecar, Vespas
Hey everyone! I've had an R18b since 2023. I'm not entirely happy with my stock exhaust. I drilled out dics in the baffles, but didn't notice much of a difference. Meanwhile, my neighbor recently brought from USA a used R18 with a Vance exhaust, and it sounds absolutely amazing and surely very different from stock r18. The sound is MUCH more voluminous (what you rightfully expect from 1.8L engine) and it growls even when the throttle is in a stable position. Hence you don't need to rev every time you want to hear your engine.
As we are not in contact with prevoius owner we puzzled for a long time over the reason for such a difference?
Thanks to this forum we found out that the previous owner removed the DB Killer from the exhaust and installed the Healtech ese-bm1 emulator recommended here. So the combined result is great! The good thing is that you can always roll everything back if not pleased.
By the way, other guys here are curious would the servo removal give any results with just standart fishtails?
It plays only a limited role as db-reducer because the valves are (partially) closed at low throttle openings only. Additionally the flaps are open on starting. As such it does not affect the sound in the least when starting or gassing it.
Also apart from idling/low throttle use the V&H would be just as loud with/without the servos.
