I removed the servo completely today and put 2x healtech servo eliminators. Here is my 2 cents:
The sound improvement at low RPM is not worth it IMO. (I didn’t see any worthwhile improvement when I tested it unplugging the electrical cables to the servo anyway.). Maybe this applies only to my setup, as I have the 100 years model with the Akrapovic exhaust. The sound improvement maybe worthwhile with other exhausts, especially the shorties I guess…
I went ahead and did this mod anyway, based on opinions in this forum, thinking that restriction in the exhaust unnecessarily increases heat in slow traffic (or stopping for red light). Weight savings are minimal but I wanted to remove the servo anyway, thinking that the simpler the better. Also, one less exhaust component which can theoretically fail should be a positive thing. (I assume it is not a certainty for it to fail to 100% open.)
As far as the ease of doing this modification goes…. Although it is not extremely difficult, I don’t agree that it is the easiest part to remove on the bike. Remember though, I am not a retired mechanic or anything, so maybe for some people this whole process could be a piece of cake. Standing on its side stand, reaching to the low side (shifter side) from below is easy, both to remove the torx bolt and to loosen the nut of the cables as well as the cables themselves. Reaching the high side however, is more difficult. Accessing the torx bolt on the plastic cover of the disc seems to be only possible with an L shaped T25 key. Taking off the main body of the servo is easy, as the single bolt holding it isn’t tight at all. Once the nuts are loosened, and the main servo body is taken down, removing the cable anchors from their slots is much easier.
I am attaching the photo of the servo I had removed and how I fixed the servo eliminators under the bike.
