moleculo
Tonight I did the initial Brentune and then went for about a 20 minute ride. Wow - big difference. That flat spot between 3K-4K RPM is gone and the motor accelerates as it should smoothly through the entire RPM band. The throttle response is night and day, especially when cruising and hitting the gas (to blow through that stop light ) I like to cruise about 3K RPM, which I feel gives me the option to hit the gas and deliver immediate power or shift down/up as desired. That flat spot that was there with the stock tuning was a bummer for my ride style....no morel So with some simple mods: DNA stage 2 filter, drilled out exhaust, the motor breathes better and with the Brentune, the way the bike runs is better in every way. If you're on the fence about this purchase & procedure, get off the fence.
BTW, I also noticed a little more pleasant (aggressive) exhaust tone with the BT...I noticed it right away.
