I find it difficult to get a bit more bobber look and still take the misses with me from time to time ;-)The first pic are the seats that came on my bike. You could leave the rear seat on the bike when using the homage solo. IMO it would look strange. In Pic 2, I laid the rear seat on the fender so you could see what it would look like.
Mine wants nothing to do with my bike LOLI find it difficult to get a bit more bobber look and still take the misses with me from time to time ;-)
Do you happen to have the part number for the mount?Hey R18C
Todkavonic is correct. am here in Pa. I ordered it in Jan. Said backordered. Got it about 2 weeks ago. Mount came in 3 days after “ discovery”.
Looking forward to the picturesI added four 15mm spacers to the Homage seat today... so 60mm height increase now... was 690 now 750mm.... I decided on 15 thinking that it would still look "normal".... and am happy with the result. Will post some photos in a while. Seating position is now acceptable for me.
Thank you very much, you exceeded my expectations with the information. You’re right I dont think it’s noticeable unless you know what your looking for.Weather here is poor.... so I was going to go for a decent ride once weather is nicer (ie no rain) and take nice photos and give a riding impression.... anyway poor shed photos it is.....
Anyway... I made 4 off 15mm spacers out of threaded bar hex "joiners" that you get at a hardware store....the joiners are about 28mm long..... I place them on a bolt... spin them and apply a hand angle ginder to cut down to about the bolt thread... you sorta get squarish ends. I only have basic hand tools, files, grinder, welder.... you can get these hex things in different sizes... front 2 are smaller diameter of
course. At this stage I fitted then unpainted..... you could spin them on the drill against a bench grinding wheel/file/emery paper to round them if one desired... then they would have to be painted of course... maybe even some black electrical heat shrink.... you can see I'm slack.
View attachment 10054View attachment 10055
AND .... poor quality other photos
View attachment 10056View attachment 10057View attachment 10058View attachment 10059View attachment 10060
General comment..... in real life one does not notice the risers nor is the "15mm" gap noticable.... (I thought I would need to fabricate something to make this area look ok.... but now don't).... a slack person would not bother taking it apart and painting the risers. For me... at 5'11" I'm not feeling the hip issue or the issue lifting my feet to the boards that I did.... I notice my knees are now below my hips.... there's something to that I think.... and for what it is worth... whilst 62yo.... I excercise, do deep squats etc.... but struggleg with the 690mm seat height in relation to the floor boards... 750mm seems to have got it to a "ok" state.
I actually think it looks better with the homage at this height with the stock gard.... more R35 then bobber.
Also... one obviously needs longer bolts.... I had the rears in the original style (off my scrambler) and just bought a couple for the front (hardened allen head ones from local hardware.... you dont see these)
I will post some better "over all look" photos when I ride it.... probally tomorrow.
Also.... given the frame angle.... for a given length rise you come up about 2/3 and back 1/3 would be my guess... the hip joint to foot gets opened up by the full ammount.... sorta right angle triangle stuff I guess.
And... if I needed to go a bit higher.... say 25mm.... then I'd consider leaving it as 15mm and place a second 10mm spacer between the seat base and the brackets that screw to it.....
See Post in thread 'Hommage seat or Day rider choice.... help!' https://www.r18forums.com/threads/hommage-seat-or-day-rider-choice-help.2123/post-30190Hi all, I was thinking about changing the saddles of my r18 first edition with a more comfortable model without ruining the aesthetics of the bike. Looking in the BMW accessories catalog, I saw the option 719 saddle which is aesthetically the same as the original one but seems more comfortable. Can anyone actually tell me if it's softer and significantly more comfortable and therefore worth replacing or if it's as hard as a piece of concrete like the original one. Thank you.
Thank youSee Post in thread 'Hommage seat or Day rider choice.... help!' https://www.r18forums.com/threads/hommage-seat-or-day-rider-choice-help.2123/post-30190
Thank you for your post; I’m picking up my Hommage next weekend and intend to raise it as well. Your last paragraph … would the “lift” be as noticeable if the spacers were indeed between the seat base and brackets?Also... one obviously needs longer bolts.... I had the rears in the original style (off my
I've given this more thought.... as I'd like to try a higher seat... so I might buy some 15mm alluminium plate... enough for 2 layers... and have a play.Thank you for your post; I’m picking up my Hommage next weekend and intend to raise it as well. Your last paragraph … would the “lift” be as noticeable if the spacers were indeed between the seat
