Toyboy
I had same issue. No other way to do it. I put some anti seize in the holes and had hex head screws on hand and used those instead of the torx that came with kit. Did you end up with 2 screws left over and that chrome cover with a screw and black plastic washer ?View attachment 4747View attachment 4748View attachment 4749Well the mount came in today. I got it figured out pretty well after taking a look at your photos. It made complete sense then.
I mounted the seat to the base with the brackets. Removed the factory seat tongue and installed the block with the two screws. Clipped in the seat wire that goes no where with the plastic clip.
THE worst was bolting in the large bolts to the frame. Those were so stupid. The two smaller screws that hold down the front were easy. I got the two larger bolts started by hand but there is zero room for a socket or anything for that matter. I had a T40 torx Allen key and that won’t fit even. I sacrificed it a little and ground down maybe an 3/32” and it still barely worked. I used a t30 and that fit. Until it got to the last push, not trying to wreck the bolt head. Then got like a - tiny turn with the T40 key.
I didn’t see any other way to get to the bolt or change the sequence. I might head to the hardware store and get some stainless hex head bolts in the bmw bolts place.
Looks great though doesn’t it?
