- Joined
- May 11, 2025
- Messages
- 201
- Location
- Herzogenaurach Germany
- Bike
- 2021 BMW R18 Classic
Looks good.
If you're interested: I also switched the shift levers so the rear lever is on the outside of the shift shaft and the forward lever is on the inside. For me, that gave me a bit more room for the toe of my boot, and allowed me to set the rear lever 1 notch lower without it hitting the exhaust.
Will do.Let us know how the rubber rings hold up. I installed the Hornig extender and the O-rings on it, don't last at all. I gave up replacing them.
Ok I thought you swapped the location on the spine to allow more clearance. Not switched front to back.After months of different trials I end up with this..... the front lever mounted to the rear allows it to be lower and clear the fish tail exhaust flat bit....
Red64, NoelPolar switched his shift arms front to back; I switched mine inside to outside on the shaft.Ok I thought you swapped the location on the spine to allow more clearance. Not switched front to back.
I have the classic so maybe not as much issue with the clearance.
How do you find the rubber rings on the wunderlich extension I see you are running as the front one?
Ordered the front one for my bike. Stupid expensive, but it works well.View attachment 17940
Upgraded the gear shifter extensions. Both front and back extensions added.
Adjusted the front to lower and back
Will update impression after next ride.
I made the same modification to my 2022 Transcontinental. I could barely "locate" the shifter pedals without it, having to turn my feet inward very uncomfortably before I made the mod - the same with my brake pedal. These small changes made all the difference in the world.View attachment 17940
Cu Dubh, we must be fairly close as I live near Portersville?Looks good.
hoping sooner than later, do you know Joe Burns? are you a 4Winds rider?Fairly. I'm up near Franklin. Waiting for the roads to be free of salt!
Not quite 12, but I'm 11.5 and was considering the extensions. I've gotten used to having my feet kinda out toed (duck foot). Lets me slide my foot forward past the edge of the floorboard even. The bad part is what some mentioned here, having to lift my foot back and up to find the downshifter. I've learned to just deal with it. The more I ride, the less of an issue it's become.Curious, where does your foot tend to rest? I have size 12 feet and find it awkward and don't know where to rest my foot. I end up resting my heal on the shifter but then need to hold my foot up slightly which isn't that comfortable after a long distance. My foot doesn't fit in between the two shifters. I have thought about potentially just removing the heal shifter but do like the action of shifting with my heal if I'm shifting a lot.
