D
Deleted member 1344
Guest
Altering the plastic holder seems a good fix.
If you had to Dremel the tray, then it didn't fit great.My Samsung S21 Ultra fits great. I did take the phone holder out and modified it though. Took a dremel and cut the bottom out of the bottom brackets and added a thin strip of foam across the bottom so the phone doesn't get scratched from the vibration. Will see if I have a pic.
That is a correct statement, "it didn't fit great" but now it does fit great.If you had to Dremel the tray, then it didn't fit great.
I know it seems unheard-of that someone would alter motorcycle part to fit their needs.Altering the plastic holder seems a good fix.
Wait, you have no maps displayed on the 10" screen ? I've got the B and I get maps on the screen once I download them onto the phone via the BM Connected app - that didn't happen / work for you ?My previous phone was the iPhone 12 pro max. They are identical in size, but the camera on the back is about a 16th of an inch differently sized, so I could not use the same case.
Exactly! When I downloaded the app on my phone and linked it to the infotainment system, I THOUGHT the display would be just like a Garmin, showing me an actual map. Disappointed to see that it was only turn-by-turn directions. If there was an easy way to mount a Nav VI on the handlebars, I would consider it.
What are the physical dimensions of your phone?I just got the iPhone 14 Pro Max and it does not fit. The plastic brackets at the back of the compartment are about to about to get removed.
My 13 Pro Max fits fine. The 14 is the same height, narrower and only 0.2mm thicker looking at dimensions so it makes no sense that it doesn’t fit? Or do you have a case fitted?I just got the iPhone 14 Pro Max and it does not fit. The plastic brackets at the back of the compartment are about to about to get removed.
I have a slim-line case around the phone. Would like to take the case off but had single drop on a previous phone (in a restaurant parking lot) and badly damaged it.My 13 Pro Max fits fine. The 14 is the same height, narrower and only 0.2mm thicker looking at dimensions so it makes no sense that it doesn’t fit? Or do you have a case fitted?
Google Pixel 7 Pro [6.4" x 3.0" x 0.3"]: Any R18 owners know if the Pixel 7 Pro fits within the R18 B/TC smart-phone compartment? R18 B Owners manual states 6.4"(162mm) | 3.1" (78mm) | 0.35" (8.8mm). I cracked my Motorola RAZR and it is a ridiculous price to repair (more than a new purchase..)
