Tube or Tubeless
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Calboy
Ulrich: Ride-On is extremely popular and sells out frequently. Most of the better bike shops also stock it. It goes back into stock quickly...keep monitoring and/or call the factory number on the website.
Most likely I will stick with my tubed tires as well ... I like the looks of spokes and tubes have never bothered me and/or caused me any issues ... this said I was intrigued by that 'RideOn' stuff
you are talking about only to see this on their website ...
This was the product I used, which uses a polymer technology as opposed to foam type products. The Ride on looks like it might also be polymer based.
https://www.puncturesafe.com/index.php
There are kits to help covert spoke wheels for use as tubeless. Expensive option would be to change wheels for alloy versions.
Believe it or not I put four coats of flex seal not the spray . It comes in pint cans . It works great. It is labor intensive.
I wonder if a polymer liquid sealer would be enough to repair any imperfections in a rim fitted with Outex or similar 🤔
