Transmission and final drive fluid .
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter johndeeredr
johndeeredr
madera ca
R1800B
Got a 2022 R18B . I’m not going to pay for BMW OEM oil . Just about adds up to monthly payment! So what do I use . I’ve have always used Bel ray 85-140 hypoid oil in my Harley transmission and it ran just fine . Can I use the same oil in both trans and final drive ?
Mopar makes exact replacement lubricants and it is way way less expensive.
Mopar SAE 70W-80 Synthetic Axle Lubricant (GL-5) 68227765AA
Mopar GL-5 Synthetic Axle Lubricant SAE 75w-85 68449546AA
I use Bel-Ray Hypoid 80-90 the weight ratings are closer to the BMW oil and I have had no problems ...
I need clarification on the distinction between Hypoid 80-90 and Hypoid 85-140. Is the latter for hot climates and the former for cold climates?
Would it make any difference to use either/or?
