EricD
1600 miles on the TC…while using reverse it simply crapped out. Has anyone else had reverse stop working? Come Tuesday I will be scheduling a service call with my BMW shop.
Note: This feature currently requires accessing the site using the built-in Safari browser.
No worries.The R18 has a personnality and there is a bit of a learning curve.Plus,I had a loose nut behind the handlebars(ME) but my wife helped me figure that out.Problem solved.I do recall that the reverse light was blinking after I lost reverse. I rocked the bike back and forth and took it out of reverse and then back into reverse and still had no reverse. When I got home from the ride I tried reverse in my driveway…no dice, no reverse. After reading the replies I went out and started the bike and tried reverse….and it worked for me! Thank you all for the help it is much appreciated.
LOL ... first time I tried mine I thought it was broken as well .. had the kickstand down duhhNo worries.The R18 has a personnality and there is a bit of a learning curve.Plus,I had a loose nut behind the handlebars(ME) but my wife helped me figure that out.Problem solved.![]()
Sounds like a warranty job...So I do have warranty for another 2 months... im on the phone with the dealer and they say its most likely the control unit for reverse![]()
Not as far as I know of. It's just the starter motor and actually a REAL reverse gear mechanism in the gearbox!Anyone know if the reverse has its own control module? Also did anyone get an extended warranty?
