Petrus
- Joined
- Jul 18, 2025
- Messages
- 1,411
- Location
- Vva. del Rosario - Málaga - España
- Bike
- R18 sidecar, Nimbus Type C sidecar, Vespas
If I don't get controll of my thoughts, I can see myself looking at the two top panels whilst thinking about what metal in them can go..... like maybe lengthen the slots behind the side pates, cut some away at the top.....
The simplest would be enlarging the top opening. Now thát would imo need a mesh to discourage rodents to overwinter up there. For the rest it would not do much harm to do away with the filter entirely unless you plan do cross the Sahara or go do rally raids. Normal road use sees not much dirt collected in the filter. It would only test marginally more Si in the oil or more cil. wear under above mentioned circumstances or at véry high mileage.
Insects and critters like that would be simply chewed up, passed through and burned off.
But then there is no worse fear than the fear for fear itself
Don´t overthink. Less still them who do not master the subject
