GB506
I have 2800 miles on the clock though I’m not positive when the problem occurred.
Good grief!!! I will be doing that in the next 6 months. I just went and checked mine and it seems alright but definitely something to look out for.I have 2800 miles on the clock though I’m not positive when the problem occurred.
Well, the headlight has already arrived, they called me from BMW to put it on Monday, I suppose it will be a headlight with the defect repaired
Llevé la moto con el problema a bmw el 15/02/23 y estoy en barcelona españa y alemania no queda lejos, preguntare si han solucionado el problema, puede ser en el faro y como tu digan los batidos de carenado y comentare por aquiPude hacer que mi distribuidor de BWM (un viaje de ida y vuelta de 5,5 horas desde mi casa) diagnosticara el problema desde lejos con una foto. Pidieron el faro de reemplazo, pero confirmaron que está pendiente. ¿Cuánto tiempo tardó en llegar el tuyo después de que lo ordenaron?
Mi sospecha es que el carenado vibra considerablemente más de lo que puede soportar el conjunto del faro. Creo que la mejor solución a largo plazo no es necesariamente un faro más robusto, sino una reducción de la vibración del carenado de alta frecuencia.
I'm going to ride into work tomorrow, I'll see if I can stop by and have them take a quick look and verify the failure; at least, they can start the warranty and order process in getting a new headlight.My TC headlight looks like yours, has the same offset on the side.
I'm just starting to see some fine particulate on the corner where you see the rubbing.
I've not seen it move from that position and have not noted light beam adapt while riding.
Will talk to the shop tomorrow about taking a look at mine to verify operation and look at the rubbing.
Good luck and looking forward to hearing what they have to say.I'm going to ride into work tomorrow, I'll see if I can stop by and have them take a quick look and verify the failure; at least, they can start the warranty and order process in getting a new headlight.
More to follow...
Service Manager went outside and inspected the headlight and took some pictures; he's going to circle back with me on getting it replaced.Good luck and looking forward to hearing what they have to say.
It should not happen on any vehicle, let alone a premium one. This may be an inconvenience but do you reckon that when idling the bike at a traffic light etc, is worth keeping the hands on the handles to somehow dampen the vibrations an hopefully prolong the service life of the headlights? I am thinking that once the bikes are out of warranty, if BMW does not do a recall or something we are going to end up with a lot of headlights miss aligned or thousands out of pocket to get the issue rectified.
I have been doing this on mine in any case and does not bother me, but that’s just me.
It’s a mega bike - don’t let these issues put you off. Just get a warrantyThese kinds of problems really make me hesitant to go out and buy a R 18 B with this setup. Knowing how most german companies are a royal PIA to deal with when it comes to warranty repair, plus how many get upside down on the price of these that they can't get out of the bike... just kind of makes me want to pass on buying one and go look at something else.
I expect BMW to be top notch quality, has it fallen off that much, or are they using cheap sub contractors on these lighting systems?
BMW first had an adaptive headlight on the K1600 back in 2010, so it’s not the first time they’ve done this feature. But, each model has a different part # and may have variations in the mechanism. The original K1600 version was very complicated with a moving mirror setup. Generally all these systems are based on lean angle, so you may not see any movement just moving the handlebars.I have a feeling that they would not know because at the end of the day this is a fairly new product to the market and although they sell the product, they don’t ride them as often as one of us would therefore, the only way of gauging this issue is by Motorrad receiving a considerable amount of claims via the dealerships requesting they send new headlights for replacements. This will tell someone up there at the Motorrad HQ that there seems to be a pattern here and they should investigate and effectively do a re call. The only issue is that a recall often takes time to be discovered, analysed and ultimately approved and in the meantime a poor soul may have been out of warranty and get charged thousands to replace the headlight.
