opinions on adding a bluetooth speaker
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter aicpjim
WHAT ACCESSORY WIRE DID YOU CONNECT THE ORANGE WIRE TO?
also, I achieved a lot of stability to handlebar mounting by making the mounts angled...For example:
NOT
But more like this
Photo is attached.
I to
It should be able to be mounted given the custom adapters, but I see 2 potential issues with it.
1) It’s rather large and could block the speedometer from view. The example on Revzilla has a tank mounted speedo, so it might be better suited to those style bikes.
2) For the money, a headset in the helmet likely will be cheaper and better sound quality as the speakers are on your ears vs fighting wind et al.
I totally agree with the helmet kit; besides, wouldn't the external speaker system take away from the classic look of the FE?
Thx for the post. The "BMW" speaker looks exactly like the Kuryakyn "Road THunder". The Kuryakyn is a couple of hundred dollars less. I hooked up the Kuryakyn to a battery yesterday and played it a little. It really rocked! great volume! Company who makes Kuryakyn speakers is MTX. I wouldn't be surprised if MTX makes the BMW OEM speakers for BMW also.
Right. This is from ebay in the US (dealer store) and with a better price:
https://www.ebay.com/itm/204128300177
