- Joined
- Oct 5, 2021
- Messages
- 1,157
- Bike
- 2024 Indian Pursuit, 2019 Indian FTRS, 2023 Moto Guzzi V7 SE
- Discussion starter
- #41
Love the sound and the plate!First start up
I reckon you've nailed it. That is how it should sound.First start up
Very cool. The beach bars look great as well.
First start up
Dave, that is an awesome throaty soundFirst start up
Primera puesta en marcha
Helluva nice setup you got there Dave.
No need for a wider tire. I like the proportions of the stock size visually as well as the handling characteristics.Dave, that is an awesome throaty sound. It would be nice to hear a hard take off!! Move over Harley!! Rear end is sexy. If that rear wheel is not 200 wide, when are you changing
. I like the cool side jugs plate!! Very appropriate!! Please show side profile pics.
I would be interested to know how the cat was removed.View attachment 13468
If you’re wondering what the inside of your head pipes look like. You can see the flapper in its natural open position. It still takes up a fair percentage of the available flow volume inside the pipe. The catalyst is encased in a stainless steel mesh so it’s not as simple as hammering it out.
I agree with you on every aspect Dave! I would love 230 rear tire but handling would be scary at the Dragons Tail! But the side jugs just wants a little bit more (200) if I can safely keep the stock wheel. For the people that have made the conversion and tire experts on safety, please chime in.No need for a wider tire. I like the proportions of the stock size visually as well as the handling characteristics.
We cut open a panel in the side of the head pipe and chiseled out the catalyst then welded the panel back on.I would be interested to know how the cat was removed.
Hi Dave, I understand that when doing this conversion you have to remove the catalytic converter and fin assemblies.We cut open a panel in the side of the head pipe and chiseled out the catalyst then welded the panel back on.
The catalyst is encased in a mesh so the job is very messy.
All I can say is 'you're keen'. That's dedication, great result.We cut open a panel in the side of the head pipe and chiseled out the catalyst then welded the panel back on.
Hi @MilwDave,I said I’d document the fishtail exhaust modification project that I’ve commissioned a local fabricator to assist me with.
Here are a few pics of the inside of the mufflers after they were opened up.
Our plan is to tie the inlet end to the outlet with a SS slip pipe that provides a direct route for the gasses to flow through the mufflers.
The mesh that makes up the internal resonator will be removed to avoid any chance of ticking or rattling. The fiberglass packing will be reinstalled around the slip pipe before the outer casing is welded shut to minimize any chance of resonance.
