Nice day tody. Forecasted too so planned to go for a nice extended spin, drink/east something at the beach and on the way back test top speed.
We geared up, rolled the R18 outside and nope, nothing. Well, the red bbq grill. Waved the key fob, moved all switches, in/out gear etc but just a red light.
So dressed lighter and went with the car, taking the manual with me.
To make doubly sure it is not the voltage, put the charger on the jump connections. Should not be the issue as it was over half but... best be sure.
Comfie at the beach went through the manual which made me nóne the wiser.
Back up, disconnected the battery and tried again. Same result.
Hey... moving the fob about I díd get a response.
So, after the check up routine, pulled the clutch and pressed ´start´ upon which all went black.
Retried, same result.
Hûh
Don´t know why but with all checked, switched to reverse and that was indeed indicated. Pushed statrt and....IT STARTED. But, but, but,....
Put it out of reverse. Kept running.
Switched off retried starting. All went darl instantly again.
Turns out it is overly sensitive of the reverse lever position.
Be that as it is, it still does not solve the invisible fob thing.
With ´compound´ weird problems one gets nervous about a ground issue....
With the print/book/etc,. shop at 50 meters have replaced the CR2023. For all of 1.5€ I bought piece of mind.
Obviously tried and the electronics ´sees´ the fob aok.
