Mirrors blind spot
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Gerard
I did mine this morning. The hot glue BMW used is pretty stout. Make sure you thoroughly heat up the OEM mirror and chrome bezel and slowly pry it off. I used 2 minute slow set hot glue and warmed the convex mirrors up on a heating pad to extend the working time.
That was some VERY creative methodology! The use of a heating pad is genius!
