(longer) gear shifting lever
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter tbonesixtynine
tbonesixtynine
Belgium
R1200R R1300GS R18 KTM-EXCF-250
Hi,
I got my R18 with floorboards and I dont like them with the heel shifting and all that. I replaced them with the pegs from the R18 B that fit on the floorboard brackets. All that is fine, however I need a longer shifting lever. Do any of you know a lever that fits and has about 3cm (just over 1") more length ? I added some pics to elaborate the problem compared with some other bikes I have.
Best regards,
Hi,
Best regards,
I bought the following: https://www.wunderlich.de/en/wunder...extension-for-models-with-footboard-18200-200
It allows for adjustment back and forward. I was able to use this to set the length exactly as I like it. I also have the footboards and after adding this for front and back my foot sits exactly in the right position and has made gear shifting much better. Since you are in Belgium should be easy to order.
its the length of the pedal that is the problem, not the width of the part to put your foot on. I need more space to put my foot under it for normal toe-only shifting, so I can eventually get rid of the entire heel pedal, as I did with the floorboards..
The extended shifter also rotates up and down slightly
But have you tried rotating the shifter on the spline?
I did a combination of both to adapt the shifter to my liking.
well it doesnt help no, look at the distances on the 3 pics I uploaded in the first post, I need like 3cm extra further away horizontally, the adjustable thing does not make up for it, by far... Mine is already on the most extended position so putting the wunderlich18200-200_02_1500_blank_640x427.jpg thing on it is not gonna help as it only extends in width compatred to the old one. I contacted a customs builder in my vicinity, Im taking the bike there saturday, he can build a custom pedal from scratch to the legth that I need he claims.. we will see :)
well it doesnt help no, look at the distances on the 3 pics I uploaded in the first post, I need like 3cm extra further away horizontally, the adjustable thing does not make up for it, by far... Mine is already on the most extended position so putting the wunderlichView attachment 18927 thing on it is not gonna help as it only extends in width compatred to the old one. I contacted a customs builder in my vicinity, Im taking the bike there saturday, he can build a custom pedal from scratch to the legth that I need he claims.. we will see :)
OK sounds good. It is a lot forward
well I need about 12,5 cm space in stead of 9 for my boot to be able to change gears up and down safely. This 12,5cm is stock on all my bikes that dont have heel shifting (and I believe the standard on most bikes). This heel shifting is hurting my riding
Fwiw.... I've played with the gear shift on my BMW r9t..... the shaft on that is a 13mm spline that is somewhat common..... I'm using a honda cr 250 shifter with that bike.... lots of cheap steel ones to play with from china.... think cut/play/weld and go from there....
