Wolle
- Joined
- Sep 1, 2022
- Messages
- 35
- Location
- Warwick, RI
- Bike
- 22' R18 TC first Edition, 13' Ducati Mts
https://www.handyindustries.com/product/r-a-m-air-lift/What kind of lift would a BMW maintenace shop, such as a main dealer, use?
What they use, and should use...are 2 different things. I saw a dealer using a small sissor jack, along with a drive on ramp to jack my R18 up. I questioned him. His response was...we use anything that works. I tend to agree!What kind of lift would a BMW maintenace shop, such as a main dealer, use?
Most reasonable and I agreee. I will ask to have a look next summer when I get an annual service on my machine. Cheers.What they use, and should use...are 2 different things. I saw a dealer using a small sissor jack, along with a drive on ramp to jack my R18 up. I questioned him. His response was...we use anything that works. I tend to agree!
Brilliant - thanks!Can be lifted using the 4 lifting points on the engine/transmission or 2 front engine lifting points and the dead fish attachment points.
Toral of $100 for the pair.
Not just for motorcycles. Paid $450 for the lit 15 years ago.
Y la parte que tiene las ruedas, donde la compraste?aquí hay un boceto del adaptador de cuadro que construí para mi 2022 R18 TCView attachment 7827
Ok graciasLa unidad de elevación es parte de una configuración Triumph de Becker-Technik.de
Hornig Kern Stabi lift is great and very stable but does not lift the rear high enough to be able to remove the rear wheel, even using the highest bolt hole for the legs - there are two. With a 18mm piece of plywood using just the rear lift on its own, you only have to remove the licence plate and the rear wheel comes out fine. After removing the rear wheel you can then install the front lift and remove the front wheel.
Thanks I appreciate the info and interesting lift. My point is that i was anticipating having to buy a secondary lift but now dont have to. I am happy working with the bike only slightly off the ground, and I can store a peice of plywood more easily in my crowded garage than another lift.Once the X-518 KERN-STABI is in place and the front & rear wheels are off the ground; you can use a standard lift-jack to raise the bike even higher while working on it.
My jack has four holes that allow me to secure the X-518 frame to the lifting platform of my lift.
To the surprise of no one.Harbor Freight recalls 42,000 motorcycle lifts
Harbor Freight Tools is recalling 41,715 Central Hydraulics High Position Motorcycle Lifts -- part number 99887.
The lift welds or tubing may break, which can allow the lift to fall or drop the motorcycle, posing a risk of injury
What to do
Harbor Freight will provide a refund in the form of a Harbor Freight gift card.
Notification letters are expected to be mailed to owners April 28, 2023.
Owners may contact Harbor Freight customer service at (800) 444-3353.
aha, this one.. no wonderHarbor Freight recalls 42,000 motorcycle lifts
What to do
That is exactly how I lift my R18.What they use, and should use...are 2 different things. I saw a dealer using a small sissor jack, along with a drive on ramp to jack my R18 up. I questioned him. His response was...we use anything that works. I tend to agree!
Good to know.Harbor Freight recalls 42,000 motorcycle lifts
Can I please order one of these? The other option, Kern-Stabi does not ship to the United States.View attachment 7765View attachment 7766View attachment 7767I made a frame adapter to use the JS Jack Lift on my TC and now it’s also works perfect as a center stand for her winter hibernation
