Jack/Lift for the R18?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Deleted member 770
That jerk Scott Semone put together two YT videos explaining the lifting of the R18 B with the Kern-Stabi; probably more information than needed...
For what it’s worth. I did a two year build project on my bobber using this scissor jack.
With the optional riser adapters I could lift my R18 for virtually anything I needed.
I just don’t get the value of these adapter plates everyone is discussing.
https://a.co/d/3N8WS16
They are just looking to distribute the wight to he engine lift points and frame as designed. I have a pair of scissor jacks, just needed to know what adapters he used in the picture to hit the lift points.
Like MilwDave, a wheel chock ( fixed to ground ) , support stands and a simple scissor lift with small blocks of wood at times. Raised front , rear of bike , balanced in middle to remove frame rails for engine cover removal. Just avoid pressure on oil filter.
I question hw much access you have to anything with that large contraption and a floor jack under the bike.
The scissor jack risers lift the frame or the swing arm and provide clear access to the underside of the bike.
I need this. Is there a build file?
Hi Snider
Apologies for late reply. No file as such. Did some internet research and some help from Wolle on here. If you search this thread you should find what you are looking for via Wolle.
Does it fit between the exhaust heat shields?(guess it does if you are using it,LOL).
My jack is similar but the lift arms are to long & won't work.
Thank you for your reply.I will go look at your jack at HF.
Regards,Tom
I saw one that looks like that at menards and was wondering if it would work.
Saw one that looks like that at menards, wonder if there's a difference. But knowing the harbor freight one works is good
People seem to make it more difficult to lift the bike than it really is. I use a Harbor Freight motorcycle lift, then cut down a 2X4 and drilled holes in it allowing to put bolts through to the engine mount holes. It gives it enough space to clear the exhaust pipes and use the lift properly.
I know this thread is old, but do you have any pictures of this. Just did my valve adjustments and used a regular floor jack to lift up the back wheel creating a triangle of the jack the kickstand and the front tire. But I would prefer to just use 2x4's to make a frame.
I have a wood block I made to put the triumph on. I jack up the back end the same as above and roll it onto the block and then remove the jack.
I bought an atv jack and with the triumph lowered for the wife the jack doesn't fit under the frame rails.
R18 doesn't have frame rails just have to make your own frame. I'd buy a welder and make one but I keep spending money on mod parts and new motorcycles. LOL!
I use a 1,500 lbs floor jack in combination with the KERN-STABI X518 to lift the R18 Model B and the R18 First Edition.
I use the KERN-STABI stand to provide lifting points or act as the lifting rails; I've seen the floor jack that I have at Harbor Freight for approx $200.
Hornig makes a variety of adapter brackets for different pipes.
I bought the bolt on bracket for the Hattech pipes.
Also if you buy the extra trucks, you can easily move the bike around the garage.
I use a chock that fits both the front and rear wheels - this works good for general maintenance (oil changes). If I have to remove either wheels I use a scissor jack; but this gets tricky removing the rear wheel from a Bagger. With that long fender you really gotta jack it up!
I found on the R18 base it is simple to remove 4 heavy bolts that attach the back fender. Rotate the fender a bit and wheel is free.
At what points does the jack make contact with the bike
Here are the photos of the Big Blue Rizer lift with the X518 to carry the weight of the bike !! ! you will notice you can change the oil on this stand but I see no reason to do such as the X518 just gets in the way. I would think it would be so easy to just leave the bike on the side stand.... jp
Hi Buellwinkle
Several years after you posted these pic's, they still prove very helpful. I have the same lift as you and wanted to see how you had spread the bearer bars on the lift itself. Thank you.
I swear by the KERN-STABI X-518
Maintenance - very stable when wrenching...
Winter Storage
Cleaning & Upkeep
I'm another KERN-STABI fan. Gets the Transcontinental up enough and level for most jobs. I also use the KERN-STABI to spin the bike around in the garage (my driveway is pretty steep and a 420 kg three point turn, in motor assisted reverse and on a cross slope, is certainly doable but gives me the nervous nellies - spinning Brynhildr in the garage is a much simpler option).
Went onto the KERN-STABI website.
Couldn't see any attachments for when original exhaust and hangers have been removed.
I have shorty exhausts fitted. I can always mess around and add the original
