Not bad at all…. I would like 4k tho.I don't need 4k so I installed the Viofo MT1 with 256GB for $205 when it was on sale @ BlackBoxMyCar couple weeks ago and very happy with it.
Note: The front camera has yellow flickering are from clearwater yellow lens.
The Viofo MT1 has a box to hide. How did you install it and the cameras?I don't need 4k so I installed the Viofo MT1 with 256GB for $205 when it was on sale @ BlackBoxMyCar couple weeks ago and very happy with it.
Thanks, very niceI placed the box and all connections under the seat of the Bagger.
Positive and Negative to the battery and the Blue ACC connector tab into Clearwater/Billie Canopener brake light which I already installed prior (you can trace and tab in positive brake light),
I mounted the front camera on to the small fairing piece (Bagger/TC) under the headlight and the rear camera mount to the rear trunk rack.
The wifi and snapshot tabs mount on the left handlebar.
I use one screw method with washers and Loctite for each camera mount for easier to align it straight and less holes to drill.
I set 2minutes recoding, 230MB file size for each front or rear camera and the wireless download took about 40 seconds for each file.
