D
Deleted member 1618
Guest
I've found the BMW hardware to be a little soft and prone to stripping; my air impact wrench scarred one of the bolts when I was upgrading my exhaust system, and I was using the proper TORX size. I recently spent over $150 USD when purchasing the necessary hardware to finish up the TC Lower Leg Wind Protection project on my R18 B; I purchased a few extra pieces of hardware, plus the two extra bolts that hold the exhaust support bracket to the frame - which I replaced recently when I installed the Kern-Stabi X518 lift bracket.
I've used the cutting wheel on my DREMEL tool (pictured) to cut down bolts and such for other projects; it might be small enough to work within your space constraints, in order to create a slot for a screwdriver?
