put it in the wishlist for future ref.
Amazon says does not fit my 2021 BMW R18 Classic. Are they wrong?
How did this turn into a battery thread, from a hesitation to start thread? Back on track...
First start, cold, engine turns over but will not start at all after about 1500 miles, after being shut down on a hot engine the last time. Starting the engine, not letting it warm up, (kept Cold), then shutting it off, then trying it again 24 hours later, it turns over and starts right up immediately.
https://www.r18forums.com/threads/hard-starting.365/page-3#post-58184oh come on, it was quite natural and close enough
You lost me.
When/how, after ´cold engine not starting at all´ did you get to starting, not warming up??? So it did/does start from cold?!
It does start when cold, but only when it had a cold shut down and then you wait 24 hours and start it up again. Reread the protocol in the link I mentioned, for what does work, and what doesn't work, for troubleshooting. Something changes when put away and shut off hot, and then started cold, 24 hours later, that causes the motor to turn over but not catch and start running. You can start the motor for just a bit, shut it off, motor still cold, and come back 24 hours later, and it starts right up this time, first push of the starter button. Something ends up missing to complete ignition when put away hot, and then waiting 24 hours and starting up on a cold motor. There's no ignition or something prevents the fuel pressure from the fuel pump from pumping up the injector lines to operating fuel pressure, until the motor spins over from pressing the start button. Or there is a software parameter that is not being met upon startup, under required specifications, to allow ignition to occur.What I responded to still makes no sense:
You shut it down hot and then when cold it does not start.
Right. We are at does not start when cold no?!
Ah well... never mind.
As a generic observation, valve play can shift a bit when the bike is being run in and it can affect starting.
Back to the battery, a higher cca will kick the engine a round a bit harder which increases compression end temp just that bit, making the mixture easier to ignite. So yes a newer, different battery can make for easier starting.
The cr thus the heat source being the same, this is about that with a cóld engine the inlet tract and de large aluminium combustion chamber absorb heat amd heat is a prerequisite for ignition.
On a side note I find it going against my old skool grain that the lighting of many modern vehicles cannot be switched off for starting.
How many miles on it? Any injector cleaner? Ever ran fuel with ethanol through it?Not on mine.
Not experienced any starting oddity not related to user behaviour![]()
Just a thought as the failure to start up first time has been discussed previously on other topics. All the points flagged here are valid but I believe that if the above were the root cause, then it would affect all R18 engines.
Imo the root cause of many a gripe ranging from starting issues to production stop, noisy by desígn, including even overheating of all things, is a barely hidden agenda. My appologies to the ones whom dó have a genuine issue.
Just a thought as the failure to start up first time has been discussed previously on other topics. All the points flagged here are valid but I believe that if the above were the root cause, then it would affect all R18 engines. Now, for those having issues starting the bike either hot or cold, can you remember if you switched off the bike by using the big red kill switch or the small black power button?
I believe it has been established that switching off the bike using the red kill switch can cause issues when you next start the bike.
I use the bike minimum 3 days a week all year round and there is a gap of 24hrs minimum between usage. I exclusively use E5 fuel and my garage is not heated. During the summer there is no issues obviously but during winter is fecking cold when I go to the garage at 5:30am and my bike starts first time every time. I use the power button to switch on and off. Just a thought.
| Test Description | Methodology | Observations |
| Test A: Ambient Temperature | Start for 5 seconds, wait 24 hours, check start | First button push success |
| Test B: Operating Temperature | Ride for 30 minutes, wait 24 hours, check start | First button push fail, second button push success |
| Modification B1 | Remove fuel cap | Results |
| Modification B2 | Remove evap canister | Results |
| Modification B3 | Monitor fuel rail pressure or ECU diagnostics | Results |
| Modification B4 | Remove spark plug or monitor spark via ECU | Results |
Not sure I followed the first bit but did you mean you use the red emergency kill switch whilst the bike still rolling, i.e, moving?I use the red kill switch when rolling to kill it since the power button does not work in that case. When it's not rolling, I'm about 50% power button and 50% kill switch and almost never just dump the clutch with the brake on to kill it. I would expect to have had the no start problem on the Test A cold/cold condition at some point along the way due to my randomness in killing the bike if the switch or button was causing the issue.
Right, the only way to kill the bike when rolling is to use the red kill switch. I do this regularly when pulling up to stop lights. If you are rolling and press the black power button nothing happens.Not sure I followed the first bit but did you mean you use the red emergency kill switch whilst the bike still rolling, i.e, moving?
The way I stop my engine is by pressing the power button situated on the right handlebar control cluster. By then I have already entered my garage, came to full stop and gear box in neutral. It works. The only thing I have not done at this point is put the side stand down as I like to keep the engine running on idle for about 5 seconds in the upright position. This is to do with an old habit earlier boxer engines had to smoke a bit on the left cylinder due to small amounts of oil entering the cylinder head when the bike was left on the side stand and then switched off.
