usmcnam69
no heatGood morning sir. I attempted to take one of two bolts securing the riser to the triple so I can get the necessary 1” longer. It is unscrewing but it continues to be tight. Usually once you break loose, it becomes easier. Are they red LockTighted and need to apply heat? Regards, Tony
needed.I also used a tap to chase the threads in the riser to clean out thread lock.
