handlebar risers by Wild1
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter usmcnam69
Good morning sir. I attempted to take one of two bolts securing the riser to the triple so I can get the necessary 1” longer. It is unscrewing but it continues to be tight. Usually once you break loose, it becomes easier. Are they red LockTighted and need to apply heat? Regards, Tony
no heat
needed.I also used a tap to chase the threads in the riser to clean out thread lock.
no heat
Thank you sir! I finally got the bolts off after much effort. If it wasn’t for your support, I would have tighten them back up and left them alone for fear screwing things up. I purchased the 1” spacers from Wild 1 and made the bracket out of stainless steel. Everything was perfect w/o needing longer harnesses and fluid lines. Thanks, Tony
