Did mine with the bike on it's sidestand... easy... 62yo.... but I consider floor work, bending, getting up and down as something to always do when ever possible.... use or lose it type of thing.... and I want to still be able to ride 10 plus years from now.... and not just old fellas bikes... big'n fast ones for me!Is this a modification (removing the servos completely) that can be done without a service lift? I would be laying next to the bike on the garage floor and not sure it would even make sense to try doing this without lifting the bike up.
easily achieved on side stand.Is this a modification (removing the servos completely) that can be done without a service lift? I would be laying next to the bike on the garage floor and not sure it would even make sense to try doing this without lifting the bike up.
Well.... I removed both exhausts today.... and went looking for free noise... but none was to be had on my March 21 made FE pure. Both flaps were open as per the general wisdom of it all.....(my bike has the servos removed).
It took me 20 minutes per side.... for hopefully 10 plus years of knowing.
It doesn't make all that much difference with stick exhaust. I noticed the bigfest difference at idle and roll off after I changed the mufflers.Did the delete today and here’s my thoughts.
You definitely won‘t end up with a snarling beast afterwards but if that’s what you want you got the wrong bike.
At idle there’s not much difference but it does have a slightly smoother baseline. Where you notice it is at low speed and off the line where it gets a deeper sound sooner. It also has a few more pops and farts on decel.
There’s also the added imaginary horsepower you get which is totally there. Getting an extra 10 bhp after might not be not untrue.
Before/after start ups at the link.
There is a gap but the pegs are blocking it. The factory heat shield on the front header has a curve that creates the gap. I bought a short chrome heat shield on Amazon that tucks beneath it.
https://radiantcycles.com/
I need 2 of these? https://www.bellissimoto.com/parts/...iminator-for-bmw-s1000-and-r-1200-1250-models ? I plan on doing the DNA intake box/filter and pro race 2 shorty slip on. Id like to do the exhaust servo mod as well. Is everyone just disabling int he open position or removing the servo and flapper all together?So I have been going through all the muffler / servo threads and reading about the different approaches and results all you good people have posted. So I really like the uniqueness of the fishtails but hate the anticlimax when you start that beast of an engine. With that in mind, I have received these bad boys today and the fishtails are currently with Matt at www.therealtoyshop.co.uk for the ‘stage 2’ mod. I’m hoping that the combo of open servo and open fishtails will generate decent sound. Not looking for obnoxious, just want to hear exhaust notes and not just engine noise at idle and when riding. Will post back here with updates once fitted.
Did you ever get the fishtails back?So I have been going through all the muffler / servo threads and reading about the different approaches and results all you good people have posted. So I really like the uniqueness of the fishtails but hate the anticlimax when you start that beast of an engine. With that in mind, I have received these bad boys today and the fishtails are currently with Matt at www.therealtoyshop.co.uk for the ‘stage 2’ mod. I’m hoping that the combo of open servo and open fishtails will generate decent sound. Not looking for obnoxious, just want to hear exhaust notes and not just engine noise at idle and when riding. Will post back here with updates once fitted.
I have the servos disconnected and I am using the servo eliminators. And yes you do need two of them.I need 2 of these? https://www.bellissimoto.com/parts/...iminator-for-bmw-s1000-and-r-1200-1250-models ? I plan on doing the DNA intake box/filter and pro race 2 shorty slip on. Id like to do the exhaust servo mod as well. Is everyone just disabling int he open position or removing the servo and flapper all together?
What's the code and does it translate correctly towards a condition within the exhaust system?Just an FYI for all. I'm using the servobuddy eliminator modules and although they keep a light from flashing on the dash there is still a fault code on the ECU. Runs fine but it will show up when scanned.
I'll run the scan again when I get home but it said the ecu logs it as being partially open and stuck there. I think it stated at 15% openWhat's the code and does it translate correctly towards a condition within the exhaust system?
I removed the servos, but not the flapper valve. Removing the flapper valve involves minor welding to plug the holes after valve removal. Removing the servos leaves the valve in the open position, held in place by the valve spring.I need 2 of these? https://www.bellissimoto.com/parts/...iminator-for-bmw-s1000-and-r-1200-1250-models ? I plan on doing the DNA intake box/filter and pro race 2 shorty slip on. Id like to do the exhaust servo mod as well. Is everyone just disabling int he open position or removing the servo and flapper all together?
I ordered that part and it said it didn't fit my 2021 but the other number given given 1185159 said in the "details" that it fit 2010 t0 2023 BMW. Both of these say it doesn't fit my 2021 R18, so I ordered both and will return the one that doesn't seem right. Great info on these pages, thanks to all of you.This is what you need. Item #P318455
$60 for the pair.
https://www.revzilla.com/motorcycle/servo-buddy-bmw-s1000rr-2009-2014?sku_id=1072318
Don't pay attention to what revzilla says they won't fit. They will fit. I've bought three sets now. Did my first and second r18s, and a buddy's r18.
This is a very easy mod and well worth it. The springs will keep the valves in the full open position when you remove cables and solenoid assembly. When I get time this spring I plan on completely removing the rest the valve assembly inside the headers and can post results and what I did
