Ok didn't work for me today.
I pulled a lady over, got her to walk a straight line, got her then to place her hands on the roof of the car whilst I pattered her down. Didn't end well.
No more police motorcycle techniques for me.
A footnote with that is that the R18 front brake is linked to the rear. Using the front also applies rear braking.The best maneuver you can practice is not to use the front brake in the final inches of stop. Press firmly on the rear brakes.
Just wear a mask and a shirt saying "police". Bonus points if you can find a secondhand bullet proof vest from your local army surplus store.Ok didn't work for me today.
Didn't know that. Generally, at slow speeds I only use the rear break on the R18. Seems to provide far greater control.A footnote with that is that the R18 front brake is linked to the rear. Using the front also applies rear braking.
You have to think of dropping it like mistakenly driving off your local pier by mistake. Don't. Keep your legs out on those tight turns until you get used to the bike. The balance with those huge cylinders is very good on this bike. Impossible to fall over unless you are going VERY slow or motionless.Hi all
Following a five hour test ride on the R18 I bit the bullet and ordered the R18 Classic. Collect it early September as having to wait on a slightly customised paint job.
My question:
Any of you folks had the misfortune to drop their R18? Over a period of years I suffered three low speed, stationary drops on my Harley Fat Bob and was amazed to suffer virtually no damage. This bike leaves me a little unsettled when carrying out low speed manoeuvres and I am hoping time in the saddle will help in this area. Just wondering if, should the worst happen, will I even be able to pick the thing up again never mind the cost of damage. I guess it will be encouraging if this post receives limited response.
As you say the balance of the R18is very good but it is counter productive to have the feet off the pegs while on the move.Keep your legs out on those tight turns until you get used to the bike.
You have léss control and it raÍses your cog:
With the feet on the pegs you can can vary the weight on them, thus balance the bike.
With the feet on the pegs you have part of your weight on the pegs. With them off the pegs, all your weight is on your bum i.e. higher.
Well there it is!!! Beautiful!!!Having owned my bike for the past four years. I have great confidence during slow speed handling. Feels very balanced. You Tubers like MotoJitsu and others have been a great help in learning slow speed techniques.
Not sure, all things American do have a tendency to be bigger... Basically, a U-Turn on a single residential road; which surprisingly, folks struggle with on these big bikes..I guess we are getting lot in semantics:
During slow cornering do not get off the pegs. Keep your foot on the rear brake.
When about to stop/stall of course you do.
If the leaned over bike is starting to topple... well ... it probably will. Unless you are a trained weight lifer best take care you do not hurt yourself. It is ony a bike.
As to the experience; I dropped it. Did have the legs down but...better to lay it gently down and still pulled a musscle in my calf as I wanted to give the carming pilion ride time to bail.
@Star-Lord US size parking spaces![]()
P,@Star-Lord about 4.5 meters vs 6 meter; a third wider.
I basically alway ride with pillion and that makes me avoid iffy manouvering. Also over here hardly anything is on the flat and true to Murphy´s law there will be undulations if/where I want to turn.
In Dutch there is a very old saying; beter blode Jan dan dode Jan. Which in this light translates as better to lóók silly than to bé silly.
When at a bikers party, the access was a loose sand track with some very tight bends. One, a T-junction, on an incline. AFter the party, the club put two strong bloke there. One direction onto the T being some 120 degrees, the other thus 60 and MUCH tighter. The blokes wavved all onto the easier side but that was the long way round. So I made a three point. and asked charming to get off before rolling down/back. Problem solved no risk.
@Randy Kahn the cylinders sticking out are like a crash bar. Mind, taking about toppling over at hardly any to no speed. The valve cover covers (bb) land on the ground and keep the bike from falling over any further. On mine I can NOT see where it rested on the concrete.
And even if that cover would scratch, I think rechroming is te be preferred over regrowing skin.
Concerning manouvring at slow, tight going, the Roll mode is easier even with the brake trailing. The bike certainly does not lack any torque for that.
As to the latter in géneral, removing the exhaust flap sensors and opening up the air intake will give you that extra punch. Mind, probably no extra max. hp but low/mid range grunt.
The flaps are situated under the pedals. The servos sit under the swingarm right in fornt of the tyre. Look únder the bike and you will see both the valve unit (black plastic cover with two bowden cables going in/out from the rear) in each exhaust pipe and the servo units. If you search on this forum for exhaust servo or such you will find various threads.Anyway.....how do you get to the exhaust flap sensors......the caps at the end of my pipes do not seem removable. I
Thanks,
RK
The bren tune keeps the valves open.... so nothing to do.........how do you get to the exhaust flap sensors......the caps at the end of my pipes do not seem removable. I already have the Bren tune re map and hi performance air filter. I'm looking for more torque, more HP is not an issue.
