Dashboard aesthetics
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Cheshire Cat
Cheshire Cat
Elite Member
R18 Classic
Anyone rerouted the wiring loom to make the two cables in front of the speedometer, less obvious?
Yes. I routed mine outside of my new tracker handlebars. Though they were milled for internal routing, the exits were under the control mounts. Rather than re-mill them appropriately and risk weakening them, I went this route. Before changing the handlebars out I had wrapped the wiring in its original location with the same webbed loom as seen in the pic. It looked a lot better.
That does look much tidier.
