Connecting to the auxiliary ignition (switched) live / power supply on the left side
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter widu13
widu13
UK
2021 R18 TC
This has been covered before but there doesn't seem to be one single referenced guide to cover this, so here it is. For anyone looking for an ignition (switched) live there are two ready to cable up spare plugs on the bike. One is underneath the tank and I will show you the one which is very easily accessible under the left side cover. This is also a canbus timed delay at shutdown; of approximately 3 minutes.
To locate it, remove the left side cover and immediately behind the OBD2 connector is the spare plug. To access it, slide the OBD2 connector to the left. You do not need to remove the OBD2 connector from the stowage plug. Here you will see the plug which has a waterproof blanking piece fitted to it.
You will need a repair plug socket to join to the plug. It is BMW part number 83 30 0413 582. It has 3 wires. You will only need 2. I recommend not cutting off the spare wire. No power will be going to it, so it is safe to leave. (I don't see any reason why you couldn't cut off the plug and replace it with a cheap but durable supaseal plug and save yourselves £20/US$25)
In this case I am connecting up a powered Quadlock. By coincidence the cable was the correct length. The route chosen was to follow the clutch hose down and through the handlebars and then underneath the tank, exiting above left of and behind the OBD2 connector. The red/yellow (or red/orange depending on your colour perception) is the +ve (live) with the -ve (ground) being the brown. I staggered the wires to ensure a slimmer connection. I tagged the live with red tape and fitted insulated butt connectors (which I had trimmed the collars off of). I then used loom tape to wrap the cables.
I then cabled up the connectors and applied waterproof (glued) heat shrink and then loom taped over the top of it.
I then spent an eternity routing the power cable with fish tape and fastening it with cable ties to the clutch hose and fastening it at key points behind the OBD2 connector (shown with yellow highlighter above the cable route) until deciding that the power connector would now reside immediately underneath the OBD2 connector.
That’s it, a very simple although time consuming job. Hope this helps someone.
In this case I am connecting up a powered Quadlock. By coincidence the cable was the correct length. The route chosen was to follow the clutch cable down and through the handlebars and then underneath the tank, exiting above left of and behind the OBD2 connector. The red/yellow (or red/orange depending on your colour perception) is the +ve (live) with the -ve (ground) bring the brown. I staggered the wires to ensure a slimmer connection. I tagged the live with red tape and fitted insulated butt connectors (which I had trimmed the collars off of). I then used loom tape to wrap the cables.
I then spent an eternity routing the power cable with fish tape and fastening it with cable ties to the clutch cable and fastening it at key points behind the OBD2 connector (shown with yellow highlighter above the cable route) until deciding that the power connector would now reside immediately underneath the OBD2 connector.
View attachment 14525View attachment 14521View attachment 14523
Fantastic Info!! Thanks.
Very helpful. Many thanks.
The part number you a referring to 83 30 0 413 582 is no longer available as per my BMW dealer in Montreal Canada. Is there an aftermarket equivalent somewhere?
It is the correct part number and is available according to MAX BMW PARTS MICRO FICHE. Called REPAIR PLUG, 3-PIN-NO. 611653. $29.91. In the USA On the parts micro fiche, the section called Repair Plug, there are good pictures of many different plugs on your R18
Has anyone used this socket to power a satnav or equivalent on a Classic? I tried to order the plug from my dealer and he would not provide it saying I would void my warranty if anything went wrong electrically and I fitted this. He also said that no sockets were listed as available on the R18 Classic for Satnav or accessory use!
Keep it simple, get a Beeline Moto II.
https://beeline.co/products/beeline-moto-ii
I have been very tempted, especially due to aesthetics on the bike, but reports from where I live suggest that it flattens your mobile battery due to poor or no mobile signal. Also it does not reroute when you deviate from the planned route. If I have to have the mobile plugged in that gives me the same issue of a good power source. In the UK traffic delays etc are also an extra monthly subscription. I have a spare Zumo XT I have been pleased with, if your experience is different please let me know.
The battery thing may be an issue depending on the quality of the signal in your neck of the woods.
It does re-route (automatically or with approval) and also you can skip waypoints using the device.
The planing of the route is extraordinarily easy and intuitive on the app, way ahead of traditional GPS unit apps.
Reactions: Mac
