Bronze plating or Metallic powder coating question...
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Witsend
Witsend
Los Angeles
R18 Classic 2023 and Vulcan S 2020
In order to achieve the custom look I am envisioning... I want a metallic bronze finish on some parts of the R18.
Anyone know if parts of the engine casing can be bronze plated? Or would I be better off going with a bronze metallic paint powder coating? Specifically the covers under each 1800 emblem.
Bronze plating aluminum is likely a no go.
But the engine case doesn’t get that hot so a good powder coat job would probably be pretty durable.
Thanks for that --I may cast the 1800 plaque in bronze. Simple enough doing a mold and lost wax.
I experienced a "chrome" powder coating on a rack for my R1200C Montauk.
