g2k7s2
Good afternoon, gentlemen, can you tell me where the dwa unit is and how to change the battery in it?
Since I had this issue or warning pop up for me, I looked under the seat and in the battery panel. Nothing that I could see or fiddle around. So I called BMW showroom and an authorised service centre. Both couldn't help with what that issue is on phone or if I could do anything about it. They asked me to get the bike to showroom. They hooked it on the diagnostic computer and said the DWA alarm battery is low on voltage. (the same thing I had seen on manual & screen shot above).Good afternoon, gentlemen, can you tell me where the dwa unit is and how to change the battery in it?
Thanks a ton. As 1911tex mentioned, the pictures really make it easier to locate. Definitely a lesson for other owners, myself included. I am still the new oner of this bike and probably didn't poke around a lot, though I looked superficially by removing the left panel and battery panel. I knew this was simple, however without knowing a lot about electricals, did not want go pulling cables, connectors and fuses!Behind left hand side panel. I’ll have my left index finger on it / and arrow. Just a case of moving wires to access DWA unit.
Its the same DWA module. I think all of the bikes with an alarm use the same module.dose the R18B have that battery?
Nice. My bike is 4 years old, I bought the new batteries just to be certain of no trouble on the road. Now I can see where they go! Thank you. I also replaced the battery in the remote. And the main bike battery with a lithium battery. NOCO NLP30. Fits perfect and 15 lbs lighter!looks like it just took some time and now warning is off. Here's a small give back with a picture.
Looks like I am back with the same DWA battery issue. The replaced battery lasted just 2 years as mine were replaced in June 2024! This time I thought I will replace it myself and I picked up the CR123a batteries. A pair costed A$16. But I am struggling to access the DWA unit! I see Brett & your pictures, but my wires are so tightly wraped together, I can't move anything to get to the DWA unit! I am feeling pretty uselesslooks like it just took some time and now warning is off. Here's a small give back with a picture.
The DWA unit is behind that mess of wires, just above the battery? What is that unit just above the mass of wires in the circle?Unplug wiring harness from the DWA unit. Remove DWA unit and remove batteries.
