Battery in the DWA unit
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter g2k7s2
The DWA unit is behind that mess of wires, just above the battery? What is that unit just above the mass of wires in the circle?
I am not sure what that is. But it can be disconnected . My DWA unit is still impossible to access as that mass of wires is so tightly wrapped together, leaving no room for movement. . There is also a plastic U shaped bracket that is screwed to the battery box encompassing the DWA unit. So it is secured in a box like set-up!
