Another Navigation Question
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter jtalka
Any chance did the dealership provide a list of fixes and or enhancements with the new version; did you notice any changes or improvements?
BMW Motorrad does not release firmware updates or firmware enhancements.
One thing I noticed after the update (I don't use the Motorrad Connected app) is that the Bluetooth connection to the smartphone is a bit faster.
I want carplay!!
I want carplay!!
We all want something better than the current Navigation setup... 😵‍💫
Pulling my hair out here, or what is left of it. I cannot get my iPhone to consistently recognize and then link to the wifi which the bike puts out to facilitate the map, etc. to the screen. It is always hit or miss, mostly miss, very frustrating.
Here is what I have been doing..
1 - turn on the bike power and mount the phone
2 - make sure that the phone is connected to the bike via bluetooth
3 - In phone wifi, look for the bike's wifi, which I never find
4 - Kick off the connection app on the iphone which will sometimes say it is starting map mode
5 - hope for the best, sometimes I will get a message asking to join the bike's wifi, once that connection is made, I am good until I shut off the bike (then it is back to square 1)
Are there configuration settings someplace that I am missing? On the bike or on the iPhone (iPhone 13)
Any suggestions/information will be greatly appreciated.
Joel
Hi Joel
I put this up a few weeks ago, I hope it helps.
Hi Joel
Hi David, First, thank you for sharing! I suspect that my problem is that I do not have the latest software installed on the bike. I have the other settings as you have mentioned. Even with the correct iPhone settings it is hit or miss. Right now, my major symptom is that the phone appears to be not seeing the BMW Wi-Fi; it is either that or the bike is not sending out the Wi-Fi signal... Next stop will be to get the software upgraded. What you have described as your current state is how it should work!! Thanks again, Joel
No worries Joel.
Just an added thought, my dealer told me that BMW have instructed them not to do updates unless there is a problem, if you just ask for the latest update they might charge you, but if you tell them you can’t connect to wifi as a fault they will do the update under warranty. Not sure if this is true in every country but in Australia that is the case.
No worries Joel.
Hi David, Trust me, I just requested an appointment and stated that the cause was the Navigation not working due to backdated software. I bought this bike used with only 1800 miles on it so my guess is that there is no warranty (?). Regardless, I can still push them on it. Given how frustrating it is now to get the blasted thing to work at all, much less consistently, it is probably worth the money (but don't tell them that!). I've been looking at some YouTube videos on the Connected App and actually looks to be pretty good. Be well and ride safe! Joel
I typically start my music first (Prime or YouTube), then I start the BMW Connect app and allow them both to run in the background (Android setup); store my phone in the compartment, then I power ON the bike and then start it.
Everything comes together...
Hi Scott... I'm an android guy too. Samsung galaxy. I find using the nav function tends to drain the phone and no way phone fits in hatch designed for it if plugged in to power. what am i missing?
I recently switched to a Pixel 7 phone, which dimension wise just fits into the compartment space; which requires manipulating the USB connection in order to get it into the space, so that it continues to charge the phone while in use.
I recently converted my compartment to a wireless phone charger, which eliminates the need to use the USB power connection. The Wi-Fi air interface is a bit of a power hog, vs the use of the 4G LTE air-interface; so maintaining a power source when utilizing the Navigation system is paramount.
Not sure if the above explanation helps..?
I also have discovered that o my Iphone 13 Max I have to put face down for all to work.. Face up and the sound turns all the way down when you close the cover.
Good morning from Germany.
There is a manual directly from BMW that is not published.
Basically you should reset the Connected App on the phone once. Then the loaded maps are lost, but you can load them again.
Then you turn on your bike, start your Connected App and wait for the blue connection bar to appear on the app.
If it takes too long, then press the menu item to cancel and press it again.
Then your iPhone will ask if you want to connect to the Wi-Fi. Important! Remember the displayed WLAN name, usually it starts like this: 2W-Wifi-64:05:e4....
Say yes and the map will be displayed. To display the connection reliably, you have to go to the WLAN settings of your iPhone.
Turn off your motorcycle. Go to the settings of your iPhone, menu item "WLAN", press top left on "Edit".
Here you can see all WLAN addresses your iPhone knows. Search for the address you remembered.
Press the "i" info circle on the right. Switch the item "Private WLAN address" to OFF.
Turn on your bike, connect the app as you know it. From now on, if your motorcycle loses the Wi-Fi connection, the connection will be reliably restored.
The problem is the security settings of Apple, here the iPhone changes the IP address again and again with the setting "Private WLAN address". The TFT display then does not understand this, as it searches for the address, which it knows the first time it connects.
Omg I hope this works!! It’s really the only issue I have with the bike!!
I have my own routine; which for the most part, is pretty reliable..
Make sure your BT and Wi-Fi are enabled, and that the BMW Connect App has permission to stay on top or active.
1. I start my music app (downloaded playlist in YT Music) on my cell
2. Start the BMW Connect App - cell
3. Power On the Bike, and verify that the Navigation icon on the TFT isn't grey'd out
4. Start the Bike
5. Media Icon - Press Play (if already not playing through the speakers)
