Battery in the DWA unit
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter g2k7s2
Good afternoon, gentlemen, can you tell me where the dwa unit is and how to change the battery in it?
Since I had this issue or warning pop up for me, I looked under the seat and in the battery panel. Nothing that I could see or fiddle around. So I called BMW showroom and an authorised service centre. Both couldn't help with what that issue is on phone or if I could do anything about it. They asked me to get the bike to showroom. They hooked it on the diagnostic computer and said the DWA alarm battery is low on voltage. (the same thing I had seen on manual & screen shot above).
They wouldn't tell me where the batteries are located but replaced it in about 15 mins. From what I could see through the service floor. The mechanic opened the battery panel on left and was working on it.
The batteries costed me AUD $32(a pair) & the labour $70+GST 10% and 3 hours of my time on a working Monday. So expensive service overall.
From my research online, there are a lot of advise on how to replace DWA alarm battery on BMW GS adventure bikes. On GS, the battery is easily located under seat and requires 2 x CR123a batteries that cost about $15. I feel it wouldn't be any different on R18s, however the location probably isn't easily accessible to replace it ourselves. Strangely none of other R18 owners have had this issue or resolved this themselves as I couldn't get any help here or other forums. My bike is about 3 years old and I am sure there are R18s older than mine. Anyways may be it was just a bad battery on mine that didn't last that long.
Thought I will put it out here for any one facing similar warning.
Kate_brett you deserve a kudos as pictures are worth a thousand words as they say...Rider4life....thank you for what you had to go through in order to replace two cheap drug store CR123a batteries! I guess the DWA alarm batteries are a big secret at the dealerships....easy $$$!
Behind left hand side panel. I’ll have my left index finger on it / and arrow. Just a case of moving wires to access DWA unit.
Thanks a ton. As 1911tex mentioned, the pictures really make it easier to locate. Definitely a lesson for other owners, myself included. I am still the new oner of this bike and probably didn't poke around a lot, though I looked superficially by removing the left panel and battery panel. I knew this was simple, however without knowing a lot about electricals, did not want go pulling cables, connectors and fuses!
Thanks for all the information. I just changed out the batteries. Will the display warning reset itself automatically? Haven't ridden/started it yet but when I turn the bike on it still shows the warning.
looks like it just took some time and now warning is off. Here's a small give back with a picture.
Nice. My bike is 4 years old, I bought the new batteries just to be certain of no trouble on the road. Now I can see where they go! Thank you. I also replaced the battery in the remote. And the main bike battery with a lithium battery. NOCO NLP30. Fits perfect and 15 lbs lighter!
These forums are awesome, thanks to all that posted info/pics on this issue!
I don't have this warning yet, but my bike is 5 yrs old, and I may just change the batteries as a preventive measure this winter.
@ Bad Mike, where did you source the NOCO battery? Amazon?
Thanks again, Greg.
Looks like I am back with the same DWA battery issue. The replaced battery lasted just 2 years as mine were replaced in June 2024! This time I thought I will replace it myself and I picked up the CR123a batteries. A pair costed A$16. But I am struggling to access the DWA unit! I see Brett & your pictures, but my wires are so tightly wraped together, I can't move anything to get to the DWA unit! I am feeling pretty useless :( i cut few cable ties holding the wires together, still no luck!
