Joshminer
Hi all! Working on installing the Wunderlich America rear conversion to side plate holder as well as under seat signals also bought from Wunderlich. I removed the BMW OEM Harness and used the provided Wunderlich Harness. I have triple checked all connections between the instructions of the Kellerman Lights and the Wunderlich Harness to ensure the correct wires are hooked up to their mates. However, the lights go wild. (The blinking in the video is just frame rate, they don't actually flutter like that. My problem is that the running tail light is lighting the turn signal.....the brake light brightens the yellow turn signal portion... and the turn signals make the yellow turn signal blink.... the tail light and brake light (red light) doesn't do anything..... not sure what the heck I'm doing wrong. I'd gladly hook someone up with a reward if you can tell me what the heck i am doing wrong. All of the Wunderlich links below provide a pdf of full color instructions. Please help! I have included a video. Cheers.
Conversion Kit:
Wiring Harness:
Taillights/Signals:
Video of my issue:
Conversion Kit:
Tail Conversion - Side License Plate Holder
Check out the deal on Tail Conversion - Side License Plate Holder at wunderlichamerica.com
www.wunderlichamerica.com
Wiring Harness:
Wunderlich Tail Light Wiring Harness
Check out the deal on Wunderlich Tail Light Wiring Harness at wunderlichamerica.com
Taillights/Signals:
Kellermann "Atto DF" LED Indicator with Rear Brake & Turn Signal Light - Bullet
Check out the deal on Kellermann "Atto DF" LED Indicator with Rear Brake & Turn Signal Light - Bullet at wunderlichamerica.com
Video of my issue:
