No, an adult bike.So a wife bike.... not a girl friend bike....
This appears to be the same case for both the Model B and the First Edition; the front directional lights will only come on in cruise mode if I enable the Auxiliary Lights Fog radio button.Thanks! .. when you happen to have the interface connected ... do have a look please if you have the radio button for the Aux lights checked ...
And if the turn signals (cruising function) turn off when you don't have that checked (disabled) ... if you could ... no rush and no 'must' ... I am just very curios if it has something to do with my bike or if there is a glitch in the coding![]()
Ty some ridicules low number like 5% or so and see if that does something ... oh ... and there is a second place in the 'Coding' section that also has percentages ... maybe that one will do the trick.This appears to be the same case for both the Model B and the First Edition; the front directional lights will only come on in cruise mode if I enable the Auxiliary Lights Fog radio button.
I'm now trying to figure out how to reduce the intensity of the front directional lights when in cruise mode - no matter how small or big of a percentage change I make on the GS-911, I don't see a change or can get to a dimmed look...
Interesting. How about taking a picture from afar so that we can see the whole look?Roctane headlight conversion.
After l complete the next modification.Interesting. How about taking a picture from afar so that we can see the whole look?![]()
Collected the parts whilst in Germany €650 ( no postage).What was the cost of the ROCTANE headlight assembly?
Were you able to drop your original speedometer into the headlight assembly, or did you have to replace the speedometer?
Do the handlebars have holes in them to accommodate the electrical wiring to be routed, or do you have to live with them being wired-tied to the hydraulic lines?
Can the Auxiliary Lights be mounted back down on the front forks, or does the new headlight interfere with that mounting configuration?
I'm always weary of adding these little upgrades on the First Edition Model B, as the bike has always struck a nice balance of chrome straight off the showroom floor as a stock bike.Looking good Scott. The 719 does add a touch of class
PS. I like the mirrors. They are on my list to the North Pole since I have been a good boy this year.
Nice. Add some brown leather grip wraps and you are in business. Thanks for the cool pic.
Which exhaust is this? Baffle?Repainting exhaust
Very interesting.Straight through pipe ; no cats / baffle. Removed cat and valve section from OE exhaust ( cut ). Then used original header section and had fabricator weld in new section of pipe.
