It appears that the R18 is difficult to detect if the headlight is working properly unless you are a trained technician. All I know is that I have dim and bright lights. I don’t even know if I have the interactive turning lights w the 719 option and cruise control.Took my R18 to the dealer to look at my headlight (3 hr ride round trip through the hills in nice wearher)... all the leds are not working in the horizontal bar.... has a check light on guage..... anyway new headlight on order now (warranty).
Whilst there... I bought a new helmet (Shoei 1400)..... after loosing 15kg of body weight turns out my head has shrunk one size.... or maybe retirement did it.... this means the shell size is a bit smaller.... so I calculated that 6 less bugs will die on each ride now.... so that is my bit done for the enviroment for 2023.
I like that. If I add these lights, that is something I would want to do. Is the film on the outside or inside?Applied a protective color film to my foglights. Looks awesome...but every step forward deserves a good step backwards. Discovered condensation in one of my turn signals when I was removing the light bezels.
Thread 'Beeline Moto... classic looking and discreet nav screen'
https://www.r18forums.com/threads/beeline-moto-classic-looking-and-discreet-nav-screen.2412/
Hi KevinQ, did you use this color for safety reasons? I installed the white auxiliary lights so auto drivers can see me better. Are there other color options such as blue that might make people think that a cop is approaching? I have seen blue headlights on cars but I wonder if they are legal.Over the outside of the lens. It's a pretty thick film. I unbolted the fog lamp and turn signal, removed the bezel, folded back the rubber gasket like material that hides under the bezel, and applied the film. The film has two little tabs of excess material that I can only assume is for application purposes, that I cut off. The film was only a few mm wider han the glass so it didn't need much trimming. The bezel covers about 2mm of the outer rim of the glass so the edge of the film is actually covered and not at risk of being ripped off by wind or picked off by someone's prying fingernails.
For anyone interested, the product is named Lamin-x
I am not completely sure of the legality of the color change....but im sure the my modification isn't going to attract legal attention. As for safety, I'm sure there is some sort of argument to be made for yellow foglights being better for foggy situations.Hi KevinQ, did you use this color for safety reasons? I installed the white auxiliary lights so auto drivers can see me better. Are there other color options such as blue that might make people think that a cop is approaching? I have seen blue headlights on cars but I wonder if they are legal.
Gentlemen, I have no intentions of offending the police, which I have tremendous respect for as well as for all responders including the military. I am 20yr Naval retiree myself.Just a thought here regarding the blue color on the auxiliary lights.
In the UK one is not allowed to have any color light fitted that is used by any emergency services ( police, ambulance, firemen) so blue, red and green are out of the question. Impersonating one of these, specially the police is a serious offence.
I would have thought that in NAM you would have the same laws regarding this or pretty similar ones.
That is ok my friend, I never thought you had bad intentions, it was only an observation to cover your derrière.Gentlemen, I have no intentions of offending the police, which I have tremendous respect for as well as for all responders including the military. I am 20yr Naval retiree myself.
I believe the yellow fog light can make you more visible to other drivers. I may add the yellow film to my auxiliary lights.
Thanks for the tip. I’ve just installed mine.Over the outside of the lens. It's a pretty thick film. I unbolted the fog lamp and turn signal, removed the bezel, folded back the rubber gasket like material that hides under the bezel, and applied the film. The film has two little tabs of excess material that I can only assume is for application purposes, that I cut off. The film was only a few mm wider han the glass so it didn't need much trimming. The bezel covers about 2mm of the outer rim of the glass so the edge of the film is actually covered and not at risk of being ripped off by wind or picked off by someone's prying fingernails.
Thanks for the tip!!Over the outside of the lens. It's a pretty thick film. I unbolted the fog lamp and turn signal, removed the bezel, folded back the rubber gasket like material that hides under the bezel, and applied the film. The film has two little tabs of excess material that I can only assume is for application purposes, that I cut off. The film was only a few mm wider han the glass so it didn't need much trimming. The bezel covers about 2mm of the outer rim of the glass so the edge of the film is actually covered and not at risk of being ripped off by wind or picked off by someone's prying fingernails.
