Weekender seat backrest removal
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter SPR
SPR
Chesterfield
R18
Afternoon
Probably a silly question .... I've come into possesion of an as new weekender seat with backrest and pillion ... it came with the backrest fitted
How do you remove the backrest ?
Thanks
Ahhh .... right .... a good tug !!
Now it slides in and out a little too easily ... is there a way to adjust resistance ?
There is a screw with a ball at the back in a nut. You can tighten this a bit and try it. Do use Loctite.
Easy Peasy.
Anyone know where to look for a weekender seat with backrest? The dealer wants $1,500 for both.
