Valve adjust
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter David R
Just because a
No,
.2mm to .3mm both intake and exhaust. at TopDeadCenter.
David
youtuber mentioned the spec. Him look like work for bmw dealer,he even set the spec from his video.all other spec from him look like correct,but only the valve clearances different from your information (from max bmw?)is your information about valve clearances is from service menu for R18 by bmw motorrad?
Thank you for fast reply.
