Transcontinental Engine Guard / Highway Bar
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Daapossum
Daapossum
2022 R18 Transcontinental
Can anyone tell me the size of the Engine Guard / Highway Bar. I have read 32mm or 1 1/4 inch. I think it is smaller. Would like to purchase some Highway Pegs. The local Dealer can not answer the question and the BMW Motorrad
Customerservice.com responded with they are not able to answer that question to contact the Dealer.
It’s 30mm. I was looking for highway pegs for mine and measured it. Haven’t found any that fit a 30mm tube.
Highway Pegs. Found the 1 1/8 Bar clamp on EBay for 22.00 dollars. The Highway Pegs were off of Amazon for 59.00 dollars. Im 5-9 and ride with Boots. I still have adjustment to possably make after a few rides. NOTE: the Highway Peg set must match the same connection point as the Bar Clamp.
These are nice. Do you have links to the products?
