Tomtom install mit photos
TodkaVonic
Elite Member
R18 First Edition
After considerable contemplation, I bought my very first motorcycle GPS. Installation was a breeze thanks to the wealth of information in this forum. I did some things I haven't seen or heard speak of though, which I wish to share.
Step 1) Wiring. I attached a couple very small bayonet connectors to the Tomtom wires and heat-shrunk them into an almost terminal-like configuration to link to the wired connector under the left side panel. Positive is yellow/red, ground is brown.
Then I wrapped things with electrical tape and stowed it neatly with a zip tie. If anyone is ever able to source the proper BMW connector, I'll swap to that, but, in the meantime, this worked well enough.
2) Routing the wire. I temporarily zip-tied the Tomtom wire in place at the handlebar tree then ran the wire retrograde under the left side of the tank; tucking it where it would go and using zip ties where needed, back to the left side cover area. I bundled the excess and tucked that away. Easy.
3) Attaching the Tomtom base. My first inclination was to go with an M8 Ram handlebar tree mount. I ordered one pre-emptively. When I received the Tomtom and looked at it's base, however, I knew that I wouldn't be satisfied with it's positioning. The ideal spot looked to be to use the 12mm steering head socket, but how? Cannibalizing the tree mount was the answer. Ok, first, the M8 mount was a titch too tall, so I ground off about a centimeter.
*This is the one, and the yellow shows roughly what I removed.
Next, I assembled a home-made bar end type expanding mount---like you'd use for bar end mirrors only more narrow---using a rubber cylinder, a couple washers, and a nut small enough to work. I had to ditch the M8 bolt and go with 1/4-20 because M8 nuts are too large. My FrankenRam looked like this:
*it’s alive!
I moved the handlebars off their perch to access the steering stem hole, planted the mount, and tightened it. To clean up the Ram arm, I swapped out the plastic wing nut with a shorted allen head bolt and lock nut. It's just better looking this way. Then I attached it to the base. So far, so good.
I put my bars back and made sure there was adequate clearance for steering, then fine-tuned the angles before tightening everything up. Here she is:
Loving it.:)
View attachment 1446View attachment 1447
*it’s alive!
View attachment 1461View attachment 1462
View attachment 1460View attachment 1459
Loving it.:)
Excellent work, TV! Very clean.
Kudos for the engineering and effort TV, but a big, fat “F” for the idea. The bike is a retro modern marvel of design splendor. Slapping a Tom Tom on there, while practical, completely defaces the beauty and style of the machine.
I'm getting the impression that my thread won't help you with your nav installation.
Love it!! You did great work and I can see the usefulness of the nav, but in my eyes, this bike is so beautiful, I just want to keep it simple and naked!!
I won't lie, occasionally I think it would be nice to know where the hell I am going if I get lost on a ride, out exploring new areas. Then I pause for a moment and realize the getting lost is much of the fun for me! Takes me back to an era when information wasn't at our fingertips 24/7 365. Riding this gorgeous bike is my chance to jump off the spinning globe for a few hours and enjoy the solitude. If I have to stop by the side of the road and pull my phone nav out of my pocket, I'm good with that. I'm not ancient either, though not a spring chicken. At 52, I realize that I learned much of life without most of the technology we have today. Though I love technology, find it extremely useful and use it almost constantly throughout the day, I love those rare moments to step away from it and just relax.
A year ago I moved from a big, expensive, overcrowded sand bar in NY to eastern TN. The roads here are fantastic and numerous. So I'm still learning where they are and where they go. I love getting on my R18 and wandering down roads that I have no idea where they'll take me. And when it's time to head home, I can just let Tomtom guide me.
Hey Muck, you make too much sense! All you guys going off and being practical on me and using common sense!! LOL
There was too much lateral laxity with my set up, so I made some changes. The reason for the laxity is that the steering stem cover widens substantially just below the hexagonal bit. That was the only part of my past set-up getting any purchase for support. Not ideal. The stem cover piece is easily removable and is decorative. Here's what it looks like:
I'll have to do my best to describe what followed, since I didn't take any photos during assembly. Bottom line is that the best solution is to have a threaded and stable platform to which you can affix the Ram. I used a washer, a very tightly fitting rubber spacer (about and inch long), and an M8 threaded T-nut, in that order. The rubber spacer holds the T-nut in place.
Here's what you do:
1) Insert an M8 washer. 2) insert a rubber spacer. It needs to be really tight. I used a vise and piece of wood to protect the finish on the steering stem cover. A socket wrench socket works beautifully to really pack the rubber spacer into the steering stem. Get it all the way up the the washer. Tight. 3) now widen the hole in the rubber spacer a titch (if needed) with a drill running counterclockwise then insert an M8 t-nut. It should be snug so it'll stay in place.
Since the hexagonal part of the steering stem is still available, this installation allows you to put the steering stem cover back and to tighten it with a M12 Allen wrench without mucking with the attachment.
Once it's back in place, you need to account for the space between the bottom of the Ram ball stem and the washer you inserted into the underside of the steering stem cover. This IS the part you just tightened with an Allen wrench. The ball needs a little space to allow for attachment of the Ram arm though, so you need to lift it up somehow, I used a bunch of low profile washers but, had I just narrowed the diameter of the lower part my Ram mount stem rather than ground it off (see my original post), that probably would've been perfect. In lieu of washers, a thin-walled cylinder or metal spacer would've worked fine too.
ok, now you just thread an appropriately long M8 bolt down through the Ram ball to the T-nut held in place by the rubber spacer and, tighten it up. It's as solid as can be.
Agreed. And this by a guy who refuses to fit a cell phone mount (?).
I have a cell phone mount on my R1200C. But the chart is barely visible thru the plastic cover.
For that the Tom Tom or similar are much better.
But in fact, when I need a map, I use Google maps with blue tooth to get the directions in my helmet headphones. Its enough.
And I can keep the phone in charge in the left bag.
Have you compared a 1970 Dodge Challenger to a 2020 Challenger Hellcat?
My son has a 2018 Camaro ZL1 and my brother in law has a 1969 Camaro SS. 69 has a style that the 18 won’t be able to match for 50 more years. Performance and reliability, the difference is obvious. I think the R18 “stock”, has the best of both worlds. Style from day 1, with modern performance and reliability. I applauded VTs engineering efforts, just hate the idea of defacing the beauty.
I have a reputation of answering client e-mails literally at all hours of the night. Every time I get up to pee (2am, 3:30am, etc), I check my phone for texts and e-mails. If I see a new one, I reply. Tied at the hip, 24/7 to modern technology. I respect and appreciate technology, including the technology on our bikes, but I want to keep it’s look simple, elegant and free from all distractions when I ride. That’s all.
I agree that the R18 is just so beautiful, it's a shame to clutter it up with gadgets. But sometimes necessity is the mother f*cker of invention. I love "getting lost" in my new home state and Tomtom keeps me from staying lost. ;)
Michigan Tim, I get it. This is the first motorcycle navigation thingy I've ever had. My usual riding practice is to set out in a direction on a county road, ride for a bit, stop, check my location on my phone (if there is service), and continue. It's sort of a controlled wander/lost event which can be amazing or, sometimes, if I'm not wandering into someplace fun to ride, lackluster. Add to this the occassional uneasiness about fuel status and the displeasure of having to stop to check location/nearby gas stations/available restaurants and I felt the enjoyment of riding, of The Ride, waning.
So, after considerable contemplation (see the first sentence of the thread), I bought a Tomtom. I endeavored, and believe achieved, as inconspicuous an installation as possible, to minimize it's impact on appearance while still being functional. The install is reversible and somewhat novel. It wasn't "slapped" on there. I have yet to do more than a cursory spin around the neighborhood but found that it's obscured by the chin guard on my helmet, which is perfect since it doesn't readily distract attention. I have no desire to add helmet speakers for voice prompts or to even link it with my phone to get texts. In the end it is yielding a bit to function at the detriment of form, I agree. We'll see if it improves The Ride enough to justify it being there.
That went over your head like like a bottle rocket on a weather balloon.
