Tire Pressure
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Berardi3
We put nitrogen in Aircraft (heavy commercial ACFT) tires for the simple reason it does not expand or contract with heat. i.e. increase or decrease pressure. I initially thought it was a bunch of "hooey" when they started putting it in auto tires, but I have to say the the tire pressure change I use to get when the weather turned colder / hotter has gone away! Pressure also seems to remain constant as well. I am contemplating doing my RV trailer tires and even my R18 TC. Just need to find a tire shop in my area that can do it. The other reason its in aircraft tires it is an inert gas. Not really applicable in this situation.
This, I haven't done nitrogen on a bike, but on passenger vehicles it makes variation from temperature almost non-existent. YMMV depending on where you live, but we can easily have 50F daily temp change from morning to afternoon in the fall here. Used to see roughly 20-30% pressure drop from summer highs (100-110F) to Fall weather. With nitrogen I see 1-2psi change basically year round.
Frankly, it seems like motorcycles might benefit more from nitrogen than 4 wheel vehicles since the air volume is much lower and tires mean so much more in terms of safety and handling. I keep my 18B pretty much at spec, and check it weekly/before a decent length ride. I've seen it drop 5-10psi day over day in terms of a warm afternoon vs cold following morning. I start to notice the rear feeling a bit squishy on the road in the 41psi range. Not even sure if motorcycle shops/dealers do nitrogen fills, as I've only seen it advertised by car dealers (and the only reason our two 4 wheel vehicles have it is because they came with it and it's free for life).
