Nice pegs, what make are they?I also installed these highway pegs View attachment 5740
Kemimoto Motorcycle Highway Pegs... https://www.amazon.com/dp/B07D315618?ref=ppx_pop_mob_ap_shareNice pegs, what make are they?
That's quite tidy!
Thanks, looks like a good accessory for me. I appreciate the info.Pretty straight forward. The Kuryakyn multi comes with different attachments. So, you can place them where you want.
That was a good move! I used a 1" 1/8th in roll pin to prevent movement. Works well, would be better if a didn't have long legs, but works well enough. Especially at the cost of the pegs. I am gonna rotate mine as you have done as well.@pbosik - I installed the same highway pegs as you. Good suggestion. I added a modification to make sure they don’t move forward with my heavy feet on them. I drilled a .25 inch hole through the clamp and engine guard and installed a 1/4”-20 button head bolt with 1/4” flat washer and nylon insert lock nut. See pics attached. Now they won’t move.
