Swap Rear indicators on a TC
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1768230793#check"></use></svg></i> Discussion starter Discussion starter Joost R1200CL to R18TC
Can your local dealer supply you with EU spec
lights, it should then be a simple swap of the lights
on the panniers.
Although I would have thought that an
imported vehicle would be permitted to retain
it's original equipment as fitted in it's country
of origin.
Correct. I was able to order the lights here in Spain (€145 each) (what would have been wrong with just a simple light bulb….) Anybody have any suggestion / instruction as to how to swap these out? Deconstructing the whole luggage?
