Spoke wheel torque standard?any one know?5NM? Or 6.5 NM?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter nienchiamao
i use wrench knot each spoke found 2 of them sound not that good,so i try to know the torque spec and diy. haaa
You likely already know this but here is my free advice for this lovely Friday: Whenever you are checking and adjusting your spokes be sure and use a truing stand (or a balancing stand with a suitable device for tracking the rim as is turns). Alternatively you can make a reasonable check with the wheel on the bike by getting the wheel of the ground and slowly spinning the wheel while tapping each spoke for a similar "ring". A loose spoke will "thud" instead of "ring"...just tighten a loose one up enough (go slow) until it "rings" like the others.
