nienchiamao
Need torque my spoke for wheel...
We have another loose nut in search of a three toed torque wrench.Already? You know you’re gonna keep screwing around until you break something!! LOL
You likely already know this but here is my free advice for this lovely Friday: Whenever you are checking and adjusting your spokes be sure and use a truing stand (or a balancing stand with a suitable device for tracking the rim as is turns). Alternatively you can make a reasonable check with the wheel on the bike by getting the wheel of the ground and slowly spinning the wheel while tapping each spoke for a similar "ring". A loose spoke will "thud" instead of "ring"...just tighten a loose one up enough (go slow) until it "rings" like the others.i use wrench knot each spoke found 2 of them sound not that good,so i try to know the torque spec and diy. haaa
