lordlivo
It’s build date was august 2020 I bought it as a ex demonstratorThat's a pain in the arsenal, but she should be fine with the upgraded parts. Just curious as to your bike's build date?
To date it only has 850 miles on the clock
Put your VIN into here and will give you your build date and spec etcI have already sent some video of the blue smoke from the L/H exhaust to my dealer, they have told me just to monitor it and see how it goes! Being an Aeronautical engineer myself, I’m not totally comfortable with their response. I have asked for them to contact Bmw Motorrad to ask their opinion.
Not sure of the build date BobW, but I will investigate and revert.![]()
I'll try that little trick.The left cylinder will always smoke a bit on start-up if you put the bike on the side stand immediately after shut down.
Try this…..next time you shut down, slightly lean the bike right for ten seconds before parking on side stand.
Took the bike in for the 6k service where just a valve check/adjustment was asked from the dealership. I did the oil change and the air filter replacement myself. The valves needed adjustment so the bill was $338.00 dollars. It would have been only 225.00 if the valves were within specs.It will be interesting to see what response you get from your dealer Calboy! I cant account for the first 200miles on my bike Alex-B with mine being a ex BMW dealer bike. But from 200mls onwards I also stuck rigidly to the correct running in process like yourself.
I do feel there’s something not right, if the dealer could explain why mine smokes excessively from the L/H pot intermittently that would be a bonus to enjoying the bike a LOT more….
Your concerns about BMW and Dealerships may or may not be warranted, but that is a pretty broad brush even though I know of specific incidents where either and/or more than dropped the ball. The bike is under warranty and everything I have read about various states Lemon Laws there is a provision for repairs to be made or not as the case may be prior to filing. I am Not liking the circumstances and while it is no help, almost every OEM in the past and currently have new models that end up with problems. This is the reality of anything mechanical and as emotional as it can be, I look to see if a reasonable solution is brought forth before going to War.I’ve had my concerns Re: Dealership network BMW NA for sometime. I’d recommend formal demand notices Certified Mail and cc Nationally to elevate. Research your State Consumer Protection and Fraud Statutes (Texas it’s the DTPA.) You don’t need an Atty to file with your State AG’s office. From my past experience in Banking, the Certified Mail from the State AG’s office is always opened immediately and elevated. BMW can provide a replacement bike cheaper than they can defend an AG’s office or Class
Inquiry. The issues described are moving quickly from “normal use and enjoyment” to “health and safety”
risks. By comparing notes on the same, you can Certify Class Action.
Good Luck.
I've notice the samething ... last couple rides notice lil bit of final oil drive, leak on the hub ... let me know what happened.. thank youTook the bike in for the 6k service where just a valve check/adjustment was asked from the dealership. I did the oil change and the air filter replacement myself. The valves needed adjustment so the bill was $338.00 dollars. It would have been only 225.00 if the valves were within specs.
They were aware of the smoke coming out the left pipe and were able to duplicate the problem. The newly redesigned parts, piston and rings, have been ordered and I was told it would take about a week to get them in.
I had another problem I forgot to mention and that is the final drive weeping some dark colored grease on the final drive cover. BMW suggested taking it apart and trying to find out what's causing the oil leak.
And that's where I stand as of today, July 24, 2022.
I'll keep you posted as the story unfolds.
A couple weeks ago I noticed a smudge around the hub indicating a smidge of seepage or something but wasn't enough to spin off onto the rim like your pictures show. i cleaned it off and has not reappeared in last 1000 miles or so.I've notice the samething ... last couple rides notice lil bit of final oil drive, leak on the hub ... let me know what happened.. thank you
