Uygurcagri
Hi guys. I have mounted sharkroad slip ons. Right silencer fit perfect but left one was a nightmare. First of all mounting rod on was higher than it should be so i could not fit in mounting bracket in the middle. Had to bend a little bit. After i installed but exhaust did not go till the end. Around 40 mm.... we tried everything. Wd40, hammer hitting and etc. Finally thought that it can be because of shorter head of pipe and decided to cut the end of manifold around 30 mm. Even it did not help. I am not sure what is the problem honestly. Maybe the diameter of sharkroad is somehow wrong? Now exhaust sits like this, as you can see end hanger and pipe connection is not at the point that it should be. Luckily there is no leak at all. I am not sure is it safe to ride like this. Will it fall somehow? Any suggestions?
